Was driving around the other day and when I shifted into 3rd gear, and pushed the peddle to the floor my Bravo lost its acceleration/power; the turbo was running on all bars on the display ( full bore) but the rev's where only climbing very slowly - it's like I was bogged down.
When i got home I had a look at the brake switch and it seams to have decent travel, so I assume its not that.
The problem seams to happen every now and then in most gears around 3k when I demand full power.
Took it to Fiat for a diagnoses, no fault codes found and when road tested to check parameters they found that when the fault was present the throttle pedal sensor was not responding - they said they suspect an internal fault WTF does that mean?
Anyone have a similar issue with their T-Jet, or have any idea what might be creating this intermittent fault??
