- Joined
- Apr 8, 2008
- Messages
- 16,742
- Points
- 3,186
Just pondering if i remove the bolts that hold the suspension into the swivel hubs will that affect the camber setup? I dont think it would but would like some clarification first
Ziggy
Ziggy
Seriously? you mean the 2 bolts at base of the suspension strut?
If the holes are elongated, then yes, otherwise no. Its a while since I have worked on a punto's suspension (2 years IIRC). I think they can be adjusted, but very little, not enough to cause any grief.
cross posting! Looks like you're doing the same job I'll be tackling next weekend...removing wishbone
I thought you meant the threads, rather than the heads.
you could try
1. those funky Irwin stuck bolt sockets
Irwin Bolt Grip Remover 5PC Base set 394001: Amazon.co.uk: DIY & Tools
2. File down existing head and use a good 6 pt socket
But I'm not sure of the need to turn them - looks like you should (!) be able to mash them straight out now the nut's off.
grind both ends off then try and bash out with a punch or another bolt. often you have to remove strut and hub and do it on a bench or floor to get enough whack
