Styling Super Chips For A Brava
No mate, that not a superchip, its a resistor and a waste of money. It tricks your ECU into thinking the engine is cold so it chokes your engine and injects more fuel. You might notice a difference for a few days, but what you have to remember is that your ECU learns how you drive. So basically it will just re adjust itself to alter the fuel mix and render the "superchip" useless. If you fancy a bit more power it is easier to reset your ECU. (1) disconnect your battery for 15 mins. (2)reconnect it. (3)start your engine but let it tick over for 5 minutes before touching the accelorator pedal. (4)take it for a spin. you will notice it will feel alot more responsive and the power steering will feel lighter. it takes about 500 miles for it to learn how you drive.
Hope that helps
