Technical Sump
Technical Sump
Shaunyboyuk
a freind has a big hole in his sump on an old 1996 punto, unsure of the model but are sumps easy enough to fit with a socket set.
Also should i use gasket sealer on it?
crabbo_1
Cambs/Norfolk border
Yes they are easy to fit...though you will need a decent length extension bar to rech some of the nuts.
You WILL need sealant as the punto sump doesn't have a gasket...just a smegload of sealant round the join.
You will also need to remove the exhaust manifold to give yourself room to get the sump off...so it may be worth soaking those bolts in WD40 a day or 2 rior to sump replacement.
The Sultan
Bravo 1.8 HLX FTW
lake windermere east edge
give new sump a few coats of hammerite before fitting to stop it going the same as old one
i put 10 coats on mine
you would be wise to get the glue from a fiat dealer they will stock the stuff
shop for parts has some loctite herehttp://www.shop4parts.co.uk/index.cfm?action=catalogue.list
but I can tell you the stuff fiat have is the best I have used
make sure you cut the end of the tube vertically so your line of glue stands proud about 8mm just to make sure it gets a seal all round as the sumps are not a perfect fit
make sure the block surface is niceand clean you'll need a razor blade and lots of fine sandpaper
4 of the bolts holding the sump at either end go into aluminium so be careful not to strip these
OP
OP
S
Shaunyboyuk
Quite far away the dealers, what shall i ask for at a car spare shop?
will halfords do it?
dave
Essex/Suffolk border
halfords be dear, look in yellow pages find a motor factors or ask for RTV Sealant
if it has to be halfords look for Loctite Silicone Gasket
OP
OP
S
Shaunyboyuk
Thanks Dave, appreciate the help. I have a vast knowledge of cars but dont want to bugger something up like the sump, dont want him doing 70 down the motorway and the sump drops off, or leaks oil. Allways best to ask :)
dave
they look like the right stuff, but i dont know how big them tubes are, i get mine in a mastic gun type thing, from motorfactors about £2.50
OP
OP
S
Shaunyboyuk
Yer was looking for a silicone type tube, makes applying it much easyer, il have a drive round some motor factors tomorrow. Just got my new tool box to, so i can put it to some use :)
