Technical Sub woofer install problems
Mine isn't wired to the ignition it's just wired up to the default wires from the head unit, blue although my sub turns off when you either take the fascias off or turn the head unit off by the power off button. So depends where he's wired it to cause it should turn off by doing that unless he forgets to turn it off over night :p
Pretty sure its wired up right, the blue remote wire is plugged into the spare red wire in my radios wiring harness and in the remote slot on the amp
How do i check if its drawing power when the radios turned off
This is my old harness but my new one is pretty much the same, the spare red wire is where its connected too and is labeled as 12v/Ignition
Ok im stupid, you was right it was a blue and white wire i needed
Fixed now...hopefully
