Sub and Amp for £200??
I need an amp and a sub however im new to ice and need some advice.
I dont really want a sub already boxed as i want to make a boot build in a few months however i only have around £200 for the sub and amp.
Any suggestion welcomed.
Anything JBL from caraudiodirect.com or caraudiosecurity.com (y)
Thanks for the reply
Im looking at this sub however as im new to ice i have no idea what kind of Amp im looking for.
Also if you know any better subs for less than £100 could you possibly post a link as im hoping to save as much money as i can to put towards my boot build
Thanks :D
There no link but i can thoroughly recommend the SNG Jatt series subs £100, i just installed a pair in a Corsa tuned silly low 23hz :D and its still pretty good on music.
Let me know if you want one ill sort it out, you dont wanna go through an online shop.
Im looking at a jbl sub with these specs:
Specifications:
10" 1400W peak subwoofer
Power Handling, RMS 350W
Power Handling, Peak 1400W
Frequency Response 25Hz - 400Hz
Impedance 4-Ohms
Selectivity 88dB
Mounting Depth 5-7/8"
Cut-Out Diameter 9"
Wt rms would i need for the amp as i saw its ment to match the rms of the sub but not sure
It is always safer to match power so £350w RMS would do the job, but if set up properly you could put up to about 600w RMS through it if you want. I would seriously recommend you have it scoped though if you do.
