dumbledore
- Joined
- Jul 4, 2010
- Messages
- 745
- Points
- 144
I was driving along about 40 mph and then some noise from the front of the engine comes.The noise is intermittent, and also intermittent changes pitch. Initially I thought a wheel bearing is gone but the intermittent sound makes me think is not. Then I thought the fan may be kicking in for no reason with this heat and making some bearing noise. Upon stopping and disconnecting the fan, I realised the noise is still there. So my question before I exclude the fan is there a possibility that the fan will rotate by itself when the car is moving at speed (40 mph) driven by the air that passes through the radiator? Is is possible the fan is still at fault. I also let the engine warm up to have a listen to the fan when operated by the car and noise was not to bad, but then when I closed the bonnet a change of pitch similar the one I was hearing in the car occurred.
Can't see what other moving parts in the engine will do this as the pitch does not seem to change with car speed or engine revs.
