Ok second attempt on rear right caliper today. I have soaked it in wd and will follow advice about clamping pipe and slackening off the bleed screw, and yes I know which way it turns. Question is? When i did the left with no problem I removed handbrake lever spring. It was a pig to get back on so I did not remove it on right. Would this make a difference.
If worst case I have to replace it I have seen the site suggested by Deckchair5. Are Bravo calipers same as Stilo.
Thanks again guys
Thanks again guys
