I have just replaced the battery on my 04 Stilo MW 1.9 JTD. I did not lose the radio, but the volume on it is acting funny. Previously, I had the radio volume on 8-10 but, now I have to turn it to 20+ in order to hear it. Anyone have any ideas?
So, I opened up the stereo to find there is no volume adjuster! Its only circuits. However I did see that the panel behind the main facia is cracked just behind the volume adjuster so now I need to find a screwdriver small enough to open it up.
Worst case I will get a new stereo.
Thank's vladof. What a man! Just been out (in between showers) and had a play with the 'base/treble/fader' settings and my sound volume has returned. Brilliant!Guys, have you ever thought that you were using separate volumes for bass & treble?
Most of the people just do some custom adjusting and then keep it like that for years and forget they ever changed any settings. Press the Audio button and custom change the equalizer to your desired sound. The radio resets to flat equalizer after taking out the battery.
Stilobunny, it really depends on how your problem appeared. I would personally take out the radio and check the soldering in the volume adjuster. If you need help taking the radio off and getting to the bits, let me know.
Here's a picture of the volume adjuster, see those tiny little feet soldered? One of them makes a bad contact, and boom, no volume adjusting. It's an easy fix, and would be the first thing I would check.
Cheers.
I am STILL trying to find out what this " HIDDEN MENU" is.
