Help please Chaps,
I know this subject has been covered a multitude of times but here goes...
on start up my JTD sounds like a heap with a loud metallic clattering sound coming from the engine (drivers side). The noise after a while will usually suddenly stop, but if I put the air conditioning on it will usually come back loudly.
At first, having read the posts on engine/gearbox mounting problems, I thought it would be something to do with one of those mounts. I pulled the gearbox mount off and fiddled around but the rubber still seemed soft so I put off changing it. Reading the threads again, it appears that problems to do with this gearbox mount cause a rattling around the passenger area and that switching the air-con on reduces the rattle (i.e. opposite to my problem)
I then thought it might be the engine or stabilising mount, but I'm not convinced since I suspect that the noise would not suddenly stop and start like it does if one of these were the cause.
So could it be a pulley problem (does the air-con get driven via a known problem pulley ?)
Can anyone shed any light ?
