OldMan
Hi All,
I have this problem with my Stilo for a year now, every couple of hundred Km the engine cuts off.
The dealer did not know a solution because there are no foult codes.
He suggested replacing expensive parts just for good luck.
I think I have located the problem to the fuel pump in the fuel tank. :devil:
The current true the pump , measured at the inertia switch, suddenly drops slowly from more than 4 Amp to 2,5 Amp or less. Engine losses power and than the engine error symbol pops up and the 12V of the pump is cut off. The 12V measured near the pump under the backseat does NOT drop until cutoff!
The pump connector is socked with diesel and there is diesel on top of the fuel tank round the pump. The fuel lines (pipes) don't look wet.
Is this common? Absolutely not normal i think.
Do you think it will be wise to just replace the pump? (unit)
How do I remove the pump unit, will it just come lose if I turn it round, unscrew it?
Anyone know a good and cheap address in the Netherlands?
Manny thanks for all the help that is given on this forum, not only in this case.
OldMan.
OldMan.
