Yeah it should do but you may have a problem with the Power but that can be solved by looking to see if the Red wire matches up from the Connector on the car to the same place as your sony one. If it doesnt then it is simple to fix just pull out the wire that is in the wrong place and then click it back in using a pair of long nose Pliers to clamp it into place as the connections are very stiff.
And you mean standard Bravo sterio Connections as you are taking the bravo sterio out and the connections that you will be left with will click into the brown and black side of the picture that was shown.
