Steering wheel controls help
ianoel
South Yorks
hey,
on my 57 plate bravo i have the steering wheel controls but am struggling to find how to change the programmed radio stations eg. from 1 - 2 - 3 etc. the up and down arrows change frequency and taking my hand off the wheel to change manually is a tad dangerous.
any suggestions?
In my GPS when the stations are programmed SRC changes through FM1, FM2, AM etc and then the Up and Down arrows cycle through programmed stations.
On FM2 where nothings programmed then this cycles the frequencies instead.
hey,
any suggestions?
I'm pretty sure there have been other posts about this and you CAN'T change thru your programmed stations with the steering wheel controls (i guess this was an oversight when the system was designed) I have never found a way to do it on my Punto either. You'll just have to press the number buttons on the stereo console
That's odd I've never had a problem with that on my 57 plate punto, as long as the presets are set I can go through the stations with the up/down buttons as cycle through FM1/FM2/MW/CD/MEDIA with the SRC button.
Hi guys,
Not sure if anyone has had the same problem as me,But the controls on my steering wheel only work sometimes.Any button that i press,It just goes into the last calls menu and rings the last number dialled(which is a pain)this is even if i am just trying to flick to the next track.If i turn the steering wheel about 90 degrees to the left,The buttons on the wheels light up and i can perform all functions.Haven't been to the dealership yet,Xmas etc.Mine is a 56 sporting punto.Anyone else had this problem?
