- Joined
- Sep 8, 2008
- Messages
- 232
- Points
- 94
I'm currently replacing the LEDs in my car from orange to white and I've got to the ones for the steering wheel controls and to remove the circuit boards for those it seems I will have to remove the airbag unit from the wheel.
From the eLearn CD it seems I wont need to disconnect the electronics for it, just remove it from the wheel center to be able to disconnect the wheel mounted controls (they're wired together behind the airbag module)
Does anyone know what tool is required to do this? eLearn shows "extractor" which just looks to be a small round metal bar that slots into two holes either side of the steering wheel to depress some clips inside the wheel. There are some generic ones on ebay - anyone have experience with those?
This previous thread shows what procedure is required but not the actual tool.
https://www.fiatforum.com/grande-punto/182796-steering-wheel-air-bag.html?p=1970578
Cheers, Gavin
Edit:
Found a solution - should have searched harder first time! :bang:
Seems a star headed screwdriver does the job, possibly more to do with it being blunt ended than specifically a star.
https://www.fiatforum.com/grande-punto/165658-drivers-side-airbag-removal-2.html?p=1775279
Cheers, Gavin
Edit:
