lofty20000
- Joined
- May 13, 2014
- Messages
- 3
- Points
- 1
Hi All,
I currently have a fiat grande punto 1.4 8v, that i am having problems starting. the engine management lights is permanently on and show a fault on the temperature sensor, the sensor has been changed for a oem part, and the light stays on and the problem remains, it usually takes about 15 times before the car will start and when it does you cant press the accelerator for a couple or minutes or the car stalls, once running the car is fine. the ECU has also been checked and that is fine as has all the wiring for any loose connections. the battery has also been checked and is fine. anyone got any ideas what could be causing the problems
