Hi all...
I would appreciate if anyone could help me with a small information regarding starting bravo 1,6 16V.
The problem is strange and it is as follows:
When I turn my key into 2nd position (before starter position) I allways keep hearing the hum of the fuel pump from behind. But not all of the time. Sometimes when engine is hot, fuel pump does not work at all, but engine still starts fine. I guess this is because there is no need for fuel pump to work, if the pressure of the fuel in injector is still high. When my engine starts, then it starts in a second, but sometimes it just won't...I keep starting it for minutes until it somehow starts. Then, if I turn off the engine and tra to start again, then There is no problems at all, again it starts in a second.
My question is, does fuel pump allways have to work when I turn the key in 2nd position, or not. What controls the relay of the fuel pump...is it some pressure indicator valve in the injector or anywhere else in the fuel system or what. Could this be the reason of my recent nightmares...
Once again, I'd be happy if anyone could help me with this one, especially if he had some similar problems....
