Hi.
Palio some times will not start, even if the engine is hot. Self cranks but will go down. I need to switch off & on the key for 3 or 4 times and re crank it back. There is no fuel pump light on, so not the issue with fuel pump. Changed the crank sensor, no result even with that. Service person has no clue what the problem could be. :worship: Any suggestions. Tried removing the battery wire and re connecting so ECU will reset, no solution. HELP HELP HELP.:bang:
