hi thanks for your reply
I had a problem last year where it would not start I had aa out auto electricians out mechanic out who suggested immobiliser she we sent it of to be repaired with the transponder ecu and two sets of keys they sent it all back but still no joy basically the people wrote the wrong software in the ecu after me sending the motorhome to another garage they thought it was fuel contamination I had four new injectors tank cleaned out all fuel lines cleaned then still no joy they went to the ecu and found the problem fixed it but now I have the same problem again
it will not start up it turns over but will not fire up
question 1 when the engine battery dies is it true the software in the ecu gets lost ?
hi charlie
cranks over ok
there is no immobiliser symbol on dash
it used to be intermittent it would not start then I would take the key out & start it back up it always started but when the battery went flat due to not using it I changed the battery then it seems to have immobilised itself
