Styling Spraying RIMS!
borny
Hello!
I'm getting bored of my normal 14-15" tipo rims.. I'm thinking of spraying them ..
Annyone knows if it is ieasy?
I dont care so much about the rims want them yellow or red.. But do i have to take the wheels of or can i just clean very carfully and the spray it straight on :) ? (Would be easy then)
pghstochaj said:
Jonny sprayed his Punto wheels black, sure he will post when he gets a minute :)
'Deed I did :D and this is how I did my alloys:
First thing is to get the wheels off the car and have the tyres taken off, otherwise it'll be awkward to mask the tyres and it'll end up messy. There's no way you can respray wheels that are still on the car without it turning into a disaster. If you need to drive the car it might be worth getting a set of cheap steelies with from the scrapper's, as it's not a quick job if you do it properly.
The wheels need to be prepped before you can spray them. Clean off any loose dirt with alloy wheel cleaner, then rub all the area that will be painted down with wet-and-dry paper. You don't need to strip them back to bare metal, but make sure to take all the old the laquer off. Start with fairly coarse paper (200 or 400 grit) to get the surface flat. This should show up any dents in the wheel, which can be filled using a decent-quality bodywork filler, then rub it flat when the filler is cured. Finally smooth the whole wheel with finer paper (800 or 1000 grit). Rinse all the crap generated by rubbing down off the rims, and dry them thoroughly.
Next you need to prime the wheels. Ordinary car primer is fine, I used one 600ml can per wheel (most spraypaint cans are 300ml so use 2). Apply the paint in lots of thin coats so that it's smooth and doesn't run. Leave a few hours between coats; I did one coat per day and left it to dry overnight.
Once the primer's on, leave it to dry in a warm place for a few days (I gave mine a week in the garage in summer), then give the primer a quick rub down with fine (1200 grit) wet and dry to smooth it. Rinse the wheels off and dry them, and they're ready for painting.
Again normal car paint is fine, I used metallic paint which also needed lacquer, but some paints don't need lacquer so check on the can first. Use at least one 300ml can of paint per wheel (I used 6 cans for 4 wheels i.e. a can and a half per wheel), again apply the paint in several thin coats (4 or 5) leaving plenty of time between coats. Once the final coat of paint is on, they need plenty of time to dry, again I left them for a week before lacquering.
Laqcuer should be applied the same way as paint, i.e. lots of thin coats, at least one can per wheel. Once they're lacquered, they need a good 2 weeks to cure, preferably in a warm place.
Right, hope that helps! :)
Ok, Cheers m8 Apriciate that! Hmm i only have one pair of wheels tho but migth take look at ebay and see what they got ? what wheels will fit my Fiat Tipo ?
JonnyBoy,
Wow, nice writeup, but man that's lots of paint!
I've used Scotchbrite (3M scourer, available from paint shops in a variety of grades, I like the purple stuff) to clean and de-gloss the wheel. Then I've sprayed on silver wheelpaint with no other primer etc. One can of paint did all four wheels...
I painted some alloy wheels metallic blue for an Uno I had. The metallic blue was a lacquer, and it covered really well. Again I just used one can (two coats per wheel), then a can of clear lacquer. Seemed to survive all right.
Recently I tried an interesting twist: wanted to match my Alfa's alloy wheels since one wheel had bad scratching, resprayed one wheel but I don't think you'd know now, it really does match the others. I used 'Steel Wheel paint', lighter silver than aluminium wheel paint. I then used a two-pack clear coat usually used over metallic bodywork. It came out with good gloss and durability.
After painting the colour, it might be worth getting wheels sprayed by a car painter with their two-pack clear coat, it has great gloss with less solvents so you don't need as much paint for a strong finish.
-Alex
I think they are not 13" they have no plastic on them.. I can take a picture and post it...
If you have a tipo with the bigger breaks on it most of the injection ones the standard fiat 13" alloys wont clear the breaks not sure about steel rims though
If you've got a mk1 1600 Tipo then they are probably 13" rims with 165/70 x 13 tyres - anyway your tyres will tell you the rim size if you look. But do you want to paint your standard steel rims, or are they alloys? I wouldn't bother unless they're alloys.
