Technical sports cat
custard
Status: DEFCON Grumpy
Edinburgh
anyone got a pic of a sports cat on a cinq?
just wondering if they look different from standard?
was looking at mine and its round whereas IIRC the cinq one is more oval,yeah?
arc
this is where i stand
Manchester
i think aarons had a sports cat fitted by vad, wouldn't be suprised if you have one too
OP
OP
custard
custard
Edinburgh
yeah thats what i was wondering.mind you im expecting it to be dead through the overfuelling.
trying to find a decent RR to get the fuelling set up this month :)
Towcester, Northants
Your cat sounds the same as mine, a bit bigger and round compared to the flatter ovel shaped standard one, and according to the VAD receipt in my service records its a spot cat as fitted as part of Hi-boost conversion.
I don't know how restrictive the standard cat is, but it is developed for a n/s 54bhp car and as such i would imagine it could strangle a turbo's 110bhp car.
I read on an alternatice forum something about cats and maybe using one from a bigger higher outout car as a good way of making the car less restrictive.
I am also looking to loose my front box and have a striaght pipe from cat to Magnex back box to again loose some of the restriction, as again the exhaust is a compromise being again developed for a n/a car not a turbo and as such not great.
Aaron.
OP
OP
custard
custard
Edinburgh
for myself im thinking of going the custom route(if i ever get out of this always skint groundhog loop im in ;)
thinking about getting a decat and whatever cat im using having flanges welded to it so it can be bolted in for MOT.
though as i said if the cat needs replaced for MOT i'll be bunging in a new one for now
arc said:
could contact vad, see what they say about the cat they used?
Yeah, tho they may try and sell you one :)
To me it looks like a standard sports cat that is then got the two ends welded on to match up to the rest of the Cinq system, but then thats how they all are.
I was thinking full custom exhaust route from a good exhuast company like Blue Flame, Stealth Systems etc someone with experience of turbo cars, but now i'm thinking that just loosing the fornt box and replacing with a straight pipe with flexy section and retaining the Magnex back box on mine would be a good and cheap compromise as I can't see the Magnex back box being very restrictive on its own, and it will not be loud as turbo cars are naturally quieter than N/A cars.
Aaron.
arc
Manchester
what about an exhaust bypass (like what viv runs on his smart). I'm still yet to hear of that on any other car. I know that some expensive sports cars have a similar system, but it switches based on flow rates / revs.
if i were to turbo charge mine, i think i'd be having one of them put in :)
beastyjay
Banned
milton keynes
i sent them an email over a year ago about getting a sports cat and they wanted just over a 100 notes plus my one.
arc
Manchester
thats not a bad price, can't see why they'd want ur old cat though :confused:
did they say who actually makes the catalyst bit?
OP
OP
custard
custard
Edinburgh
well just over a ton is okay as i would be paying that for a replacement but why would they want yours?
beastyjay
Banned
milton keynes
dunno, maybe they make the sports cats from normal cats??
suppose its like some car spares places want your old parts so they can get them refurbed and sell them on to make a little bit back.
Because they probably get in sports cat which will be just the cat and then they either use or copy the pipes from your cat to ensure that it fits correctly, therefore they can adapt them to any car.
OP
OP
custard
custard
Edinburgh
do you think i could get a discount since my cars an advert for them? :D
or should i claim on the VAD warrenty?hell it must still be under warrenty since 96 :D
Brooky
Well-known member
Lancaster
its a plating isn't it???
i have some expensively plated titanium,and its worth naff all in the scrap market, but in the car world, awsome(y)
Smiler121
Rip'n'Burn
Darkest Warwickshire
"The converter is lined with aluminum oxide, platinum, and palladium. These chemicals acting as catalysts cause the carbon monoxide and hydrocarbons to form water vapor and carbon monoxide. (Some converters have a third lining of platinum and rhodium, which reduce nitrogen oxides.)"
"Thieves are targeting catalytic converters largely because they contain small amounts of three precious metals -- platinum, palladium and rhodium. The metals are used in the lining of the converter."
Brooky
Well-known member
Lancaster
mmmmm, best hide all my stuff then,loads of tubes of planinum and rhodium plated titanium
