Hi, I have a small oil leak on a 02 Sporting MPI Seicento (finally got all the bigger ones sealed up!) It seems to originate behind the coils on the top right-hand side of the head. The cam cover is well sealed (I have also replaced both crankshaft seals and the sump). The exploded engine diagram (epiper) shows a seal behind the casting supporting the 2 coils. Is this a likely source of the small weep/leak which makes its way down the head and round the flywheel bell housing. If it is this I assume its not a big job to replace? Thanks in advance.
