Styling  Sporting Instruments in a Cinq SX?
arseofbox
Principality Retained :)
Midlands
Has anyone retrofitted dials and instruments from a Cinq Sporting into the lower models??
Is it possible? I really fancy a revcounter........ and white dials.
Trust Lockwood not to do dials for the Cinq S\SX
Arse
all gauges should work except for the Tacho. the 899cc versions are not fitted with the wiring for it. Your best bet for a tacho is an aftermarket dial but make sure it has a 2cyl setting for it to work or it'll only show half the revs;)
Is adrenaline brown?
Well, what wiring does the Sporting Tacho need? It appears Haynes in their wisdom omitted it from the wiring diagrams!!
Wiring the Sporting tacho in cant be any harder than an aftermarket one can it?
Arse
Feel the magic........the magic is coming......Shazam
maybe. dunno, the haynes manual shows a pic of the tacho connector inside the instrument box but it's only got 3 wires for it. Most Tacho's have 4 wires or more. This could prove tricky and i would consult a profesional auto-electrician[:0]
All ya have to do is wire one wire to the live power one to the earth one to illumination and one to the negative on the coil but you will need to et a 2cyl rev counter im on the look out for one but aint found one yet.
James
www.clubcento.co.uk
Right the sporting tacho has illumination by bulbs behind it, so no 4th wire.
LOgically one will be 12v+ constant,
The Second Earth
and the Third will be ignition coil pulses.
What colours are the wires.. the manual is really really helpful on this one.
Arse
it's not really wires, more of a brown plastic strip (like a ribbon cable). The manual is useful but only up to a point cos it don't show any info on wiring diagram for the tacho[V] and it doesn't indicate whats what on the strip. :(
Well could yu possibly rip your dash apart and test the voltages on each of the lines??With a Multimeter or similar.
Im dying to put a tacho in now...
Arse
Feel the magic........the magic is coming...Watch him starve himself to death!!Hehehehe
<blockquote id="quote"> face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by brickfoot
who's ray?
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Ray Lee, has a monster tach and shift light in his sei. Pics in the cinqs_&_Seis yahoo group.
Pete.
Cinq sporting 1242cc
Cinqs&Seis Yahoo group
Clubcento
yeah want a small one to pillar mount along with a water temp gauge.
I have been told that if there are no wires already behind the vent in the dash on a sei you ust use them if no you wire it from the fuse box there is a fuse for the coil. havent had chance to have a look yet but will do soon
James
www.clubcento.co.uk
