Technical Sporting Fuel Pump
16VALVE
hi. I Have 1998 Punto Sporting 1.2 . fuel Pump Has Failed Can Any One Tell Me If Any Other Pump From Any Other Fiat Will Fit . Thanks :)
Ralf S.
Well-known member
The land that time forgot
Why that? You still need that pump, whether it fits one or more models. ;)
If the Sporting has the 16v MPI engine then the pump is part no. 46427664 - the same as used on the MPI 8v engine .
The SPI and the 1100 had a different pump.
But to confuse matters, some 8v MPIs had a different fuel pump, so it's not EVERY 8v MPI pump that is the same as the 16v one.
Ralf S.
goblin
hi not sure mine went i went to scrap yard and there was 1 punto 1 so i just stuck it in and it worked defiantly was from a 1.1 but seems ok
