Technical Spark Plugs
jameshobiecat
Established member
Why on earth do fiat advise changing spark plugs every year when other manufacturers say they last 60k miles or more?
Modern engines have near perfect air fuel ratio at all times so they should last. I bet they look like new when removed after twelve months.
My theory is that fiat have aways said that and have not updated their advice in decades.
I think I will give my plugs and annual check and only replace every few years.
I changed mine after 25k miles, 2 years and they definitely needed doing, pretty sure they hadn't been changed before. I'd rather follow the guidelines and do them when Fiat tell me to, but if you want to inspect yours and have second thoughts that's up to you, at least you're still taking care of it
I'm sorry but I can't fathom why they last 60k in a peugeot and only 12k in a fiat.
My car has just had its 30k service including plugs and my friend (who works at fiat) said that the plugs were "fukd" when removed, also if you look up the original fiat part for the spark plugs you will find that they are a lot more that 12 quid unless you wanna get cheap crappy ones , since changing mine the car feels a little more responsive and runs better so all in all a good idea id say.
My sister's Fiesta had original spark plugs despite being 12 years old and on 80k LOL. She found this out when she put it in for a service. Shows you how well people look after cars eh?
I get them done annually though, regardless of what the manufacturer recommends.
Ok let me put it another way; do fiats eat spark plugs far quicker than other engines?
It is not so much the money (i'm not a scot despite the name), i'm more interested in why fiat differ so much from other manufacturers on this.
Where plug-change intervals are quoted as 60k, it's usually due to the manufacturer specifying expensive platinum/iridium-tipped versions which have a longer lifespan.
Copper-based versions are cheaper but have a service life of 10-20k, and whereas Fiat service intervals were 12k (with plugs being changed at 24k), now the 18k intervals mean the plugs would end up being well outside their optimum working lifespan (at 36k for the second service), unless you'd rather have to pop in to have have them changed between services?
From experience, NGK plugs are more evenly balanced resistance-wise than others, like Champion for example, which means a more consistant charge and discharge output needed from the coils.
Ah now we are getting to it, Fiat fit cheap spark plugs. is this true for t-jets? I have read that their plugs are much more expensive.
As do many manufacturers as it means a lower service cost.
Platinum/Iridium tipped plugs may last longer, but they're easily damaged. For example, T-jets can eat through them very quickly if used for a lot of short journeys.
