General Spark Plugs Whereabouts?
hi welcome to the forum:)
8v or 16v i think the 16v plugs maybe under a cover they will be in the middle of the top of the engine, you might have to remove an airbox first, i havent seen a 16v punto engine in real life!
8v plugs are at the back of the engine.
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
Hi welcome to the forum.
"The new rules are very simple, the FIA will keep them to themselves until such a time as Ferrari needs them" Patrick Head
http://www.geocities.com/drpepperdionysus
opps sorry 8v model..
Ive never had so much bother with an engine before.Do I need some sort of special tool to remove these spark plugs?
....and spark plug removal should be the easy thing to do!!!....
I've had my 8v 1.2 two weeks now and still pondering where the plugs are. I can see HT leads disappearing under the air box, but not what they attach to - looks like the fuel rail...
The oil filler cap is somewhat odd looking too, more of a flap than a cap!
i have 8 valve have no trouble removeing plugs, remove air box, then use socket set plug socket small one, swivell joint thing (not sure of propername) an extenshion bar and a rachet.
Yeah the plugs on the 8v are set quite low.
You'll need a socket with an extension bar - also mine took quite a bit of force to undo the first set.
Also - bear in mind that dirt etc can collect around the plug. Try to clean this area out BEFORE removing the plug. Use a hoover or compressed air etc to either suck or blow any dirt out.
And as a point to note - I used the Bosch Super 4 plugs on my 2003 8v(£19.99 from Halfords) and they're superb.
__________________________________
Yellow Punto? Bit girly isn't it?
