Technical spare hole in throttle body ?
shnowzy
lancashire, United Kingdom.
cinq sx
i just noticed there seems to be a space hole in my throttle body it is located right next to tube that comes from the top of the rocker cover it is blocked with a rubber tube that comes off easy.
can u use this hole??? for the rocker case gasses? as the one next to it is looking a bit blocked/gunky cheers
took the rubber blocking tube off and the engin was ideling a lot smother also sounded smoother a slight hiss as it was sucking lots of air into the hole
just been for a test run in it without blocking tube a lot better accelecation one cheap mod that was cost nowt lol
does ne1 know why this hole is there am i missing a tube to connect to it????:):):)
if i where you i would check under your oil filler cap if there was a load of gunk in the rocker breather pipe. could be that your head gasket has gone? if there is a white stuff there then get a head gasket asap. do you have overheating problems?
Little Red Devil
AWAITING OPERATION
(L.R.D). ICE started and put on hold. Still need a rear bumper. "its proper getting better i tell thee!"
Tubes should connect to:
-Airbox hot/cold air selector, goes from tb to under airbox to black thing at the front
-Fuel vaour from cannister, blue nylon pipe
-crankcase vent, tees off the pipe on the top of the rocker box.
If you've got an induction kit on, you should blank the one to the airbox hot/cold thing.
Pete.
1242cc cinq, turbo cinq, Cinqs&Seis Yahoo group, Clubcento
crankcase vent that tees of the pipe of the rocker box well that spare hole on the left side of that it is not missing any tubes but this tube is blocked with a blocking tube take it of as engin runs a lot smoother with it out
