General spacers
General spacers
tidus
Is there anywhere where i can buy 10mm spacers for the cinquecento that fits over the little nut and pin on the disk?
You don't want to fit them over the bolt and spire bolt on the disk. Rather you want spacers with 6, rather than 4 holes. The extra small holes are for the nut and bolt.
Alfa 155s have -- IIRC -- 8mm front spacers (and longer spire nuts to suit). You can pick them up for pennies from a scrapper (Alfa scrappers tend to be specialists, but you'll find some in generic scrap yards) these fit straight on. Or, try your FIAT dealer, as I think Aaron mentioned them doing 10mm spacers at a sensible price.
Failing that, get a hubcentric 10mm spacer from tweeks or somewhere with 98pcd, bolt a disk to it and use the disk as a pattern to drill the clearance holes for the bolt & spire bolt in the spacer.
Yes Fiat make very good as you would expect from a car manufacturer 10mm spacers as fitted as standard to Seicento Abarth MPi models, not expensive at about £30ish the pair.
this information has been written many many times on this forum and would have been found with the search.
Aaron.
