Technical Space behind rear seat side panels?
CaneyJ
Clubcento Member
Hot sure where to post this but think this is best area. I don't suppose there are any pictures floating around of the space available behind the backseat side panels as I am looking for a place to locate a future installed amplifier.
The other option would be to screw an mdf panel to the underside of my cinq drivers seat and screw the amp to that.
an amp wont fit inthe side panels in the back the best place would be in the boot mate
There may be room, depending on the amp but mounting it and keeping it cool would be a problem...........
Do you mean having the amp upside down?
I would strongly recommend you DO NOT do this. The heat produced by the amp would just rise up back into the amp, causing premature damage (n)
There's probably enough space and air to fit an amp (unless it's a monster like one those silly things I bought), but TBH, it would be a lot easier to just shove it in the boot.
Under the drivers seat is a bad idea, chances of it getting booted / wet / covered in dog **** are too high!
