Hello all,
im back with some major engine repairs done to the 1.4 mk1
fixed(turned head/tails) in the ring wheel of the car. now the car is starting fine as it should without any cranks in the engine. it was not a prob in the starter motor.
re did the clutch-plate. spent like a week to get used to the newly lined clutch plates.
removed gearbox and changed the oil, and lower arm/suspension bush issues and all.
removing the gearbox and ring wheel seems to be a pain in the ***
removed the thermostat from the radiator as it was blocking the coolant and the car gets hot easily due to the thermostat not working properly.
serviced the alternator.
btw for all who helped me in finding a windscreen from UK, we did
, but couldnt ship it because of the costs, i brought a singapore one down from a local windscreen shop hehe
aaand the only downside now is the fuel consumption. it does like 7km/l in the city with AC on.
also, is there a factory fitted AC switch that comes with the bravo mk1 dashboard? just asking because i have mounted a custom switch to turn on/off the AC.
