So, after getting my missis a nice little sporting a few weeks back, i decided i wanted one, but wanted one with a bit more poke..
After looking at about a million of them, ranging from none runners, to ones priced at £2k I've settled on a 2001 HGT abarth.
After driving it home and having a proper look around it, i've decided it's a toilet and i've lovingly named it "Death shed", But this is ok as it was cheap, and after looking at it before parting with my cash, i wasn't expecting much more!
so, i'll list a few of the falts and hopefully someone can give me the most likely cause of them, so i know what to look at first.
1 - the car was a cat c in 2010, it's had a shocking repair, and the panel gaps are miles out, i've got it looking nearly right, but the bonnet is still sitting to far to one side, how do i adjust it, or do i have to move the wing in a bit further.
2 - airbag light is on, i suspect this is from the cat c incident, do i have to take it to the main agent, or can i do it with a fault code reset tool (i have one, also have a usb obd2 interface, is there a software available for reset?)
3 - car only has 5 gears, is this right for a 51 plate HGT?
4 - gear linkage is sloppy, what is the most likely cause, what do i buy to fix it?
5 - there is a clonking noise when i dry steer, the noise is made by a coil spring, why is it making the noise?
6 - the top mounts, where they come through the inner wings, the hole is elongated, is this to make adjustments to the caster angle, or should the mounts move? i ask as one is fully forward, the other is fully back!
7 - and lastly, there is no record of a belt change, as 70% of belt failures are caused by incorrect fitment, i'm going to pay a garage to to change it, what should i expect to pay for this?
i'll leave you with those for now, but i'm sure i'll have lots more questions as time goes on.
TIA
Red
TIA
Red
