Geoff21
A friend recently bought a 2017 Ducato panel van. The sliding door worked OK to start with but then refused to open with either the inside or outside handles although the central locking can be heard to operate. When I investigated I found that on the main lower latch the plastic cover that surrounds the metal latch has been damaged at the top and now stops the latch from retracting into the mechanism. I managed to get it to work by pushing the plastic part back but it keeps springing back out. Does anyone know if the plastic cover is essential or can it be cut off? If it is needed, is the cover available or does it need the whole lock assembly replacing? any advice would be greatly appreciated. Thanks in advance.
