Technical service mauals.
Stationerystill
Has anybody had any experience of downloading a service manual from emanualsonline? I tried it for my Ducato but it took 6 hours and then my computer was not able to run the software needed to read it.I have a 30mb fibre optic cable connection.
regards Stationerystill
Hi
If you are looking for the eLearn for the 244 models it is available in the downloads section of the forum as is the X250 elearn, in split files or you can try the link below which is one file, an ISO compressed in rar file.
Here is a link to the 02-06 eLearn Workshop Manual for the 244 models -
http://www.filefactory.com/file/5sts...cato_02-06.rar
Wait till their page finishes "loading" then Go to the bottom of the page & select Download from "Slow Download" then after the countdown completes & go from there, also untick use filefactory download manager.
It is an CD ISO image compressed in a RAR file (111MB) so you will need Winrar to uncompress the file (free on the net) which will give you an ISO image which you then burn to a CD (as an image) using Nero or similar program. Then insert the CD in the drive & it should auto start the installation on your computer. Just follow the prompts, when finished there should be an eLearn icon on your desktop to start the program but the CD has to be in the drive when using the program. When you start the program select the language in the top left - english then select the engine size. Then click on the Blue Ducato van at the top & select from the menu on the left.
Hope that helps
