Technical Serpentine Belt Plastic Cover Upper
mswizinbiz
Good afternoon all, my serpentine belt decided to partly come off of the upper cogs & has cut right through the plastic cover that sits right beside the plastic bottle radiator filling thing. I need to get hold of a replacement cover but Fiat can't help due to the age of the vehicle. Can any of you lovely lot help or at least send me a picture of the cover as mine has a big hole in the middle. Thank you & stay safe out there.
Near the M4
Hi
The forums version of ePER doesnt seem to cover the Sedici
I owned a JTD engined FIAT estate car.. and dont recall any cover on the Aux drive belt..
But a wandering cambelt did saw its way through its covers..
Wrexham, North Wales
Hi
My ePER (2014) covers the Sedici and could only see the cam belt cover. Available from Fiat in 2014. Two covers listed so VIN required.
OP
OP
mswizinbiz
mswizinbiz
Do you mean the cam belt cover? The serpentine belt that drives the aircon, generator, etc. does not normally on most vehicles I have owned have a protection cover.
Yes the cambelt cover, it's to the left side of the engine between the oil filler cap & radiator bottle thingy.
My belt moved off its line & cut through the thin plastic cover.
Near the M4
Showing as Discontinued..
But new one available in Germany..
Used in Italy.. its a standard JTD cover apparently
Where do you see it as discontinued?
Do you have a Fiat parts listing you can point us to that shows this a discontinued?
OP
OP
mswizinbiz
mswizinbiz
Yes this is the one bit I don't understand Italian 😀 how much is the one in Germany & do you have the link?
Yes I've called Fiat UK retailers the part & it's been on back order forever & they doubt it will ever come into stock again due to the age of the vehicle.
OP
OP
mswizinbiz
mswizinbiz
Thank you 🤗
OP
OP
mswizinbiz
mswizinbiz
Thank you varesecrazy 🤗
Near the M4
My damaged cover just got repaired..
But you can probably find a JTD motor being broken in the UK..
This part appears to be the regular part for punto's
I take it that your idler bearing failed.. thats how my belt wandered..
