Technical Semi auto panda stuck in reverse
Thanks for that Jon it could be helpfull to know although i believe it should not start without foot on brake, if you or anyone else can help with another check, the 3 solenoid looking items at the back of the gearbox on top have labels on the wires that go to them, stood in front of the car with these solenoids at the back right hand side the stickers on the wires that go to them reading left to right are marked EV1, EV2, and EV0, is yours or anyone elses the same ?, also on a seperate note i need a fuel system purge valve for the same car does this have to come from the Fiat dealer or are they available from elsewhere, thanks.
Hi Jon, did you get chance to do any checks as ive still got this to sort ?, im thinking the problem must be related to the car starting without putting my foot on the brake, do you or anyone else know if there car starts without putting there foot on the brake, thanks.
I've just checked, car will start without foot on brake if in Neutral but not if in gear, so it would seem this is normal, and the gearbox actuator wiring labels match as well. Ours is a 2009 (July 09 registered so nearly 3 years old) Eleganza Dualogic.
So would see the starting in neutral thing is normal.
