General seicento key
Luke M
Formerly mog1571
widnes, liverpool
hi guys
managed to snap my blue key in half at the weekend while away in the middle of staffordshire 100 miles from home. luckily my mates parents were bringing his new car down so brought the spare with them. so i need a new key. ive seen you can buy them off the internet but how much would it cost to get cut and linked? or would it just be cheaper to go straight to fiat and get one off them?
why did they make the keys so weak! :confused: :confused:
cheers
luke
EDIT its a 2001 sei so no red key
OP
OP
Luke M
Luke M
Formerly mog1571
widnes, liverpool
so the blue keys that you can buy on ebay which they say just need a key cutter to cut then a garage to link wont work?
LanciaMad
Prominent member
Toon
Correct, they are for the older key type (with red key combo).
I myself only got one key with my 2001 sei, I just got a cheap key cut (so that if I loose the real key I can still get in and undo the steering lock).
and if I loose the real key I will just order one from fiat (they order them from italy off your chassi number).
AppleSei
RIP L181 VBB
West Yorks
The blue key which you snapped is a code2 key, your other key should have a 'C' and a triangle shape and a number 2 on it to confirm this, this key has all the imoobiliser information within it, your car will not start if you purchase this other key on ebay
However if your sei was made before approx 1999 then you can purchase the blue key on ebay as seis before that date were more likely to have had a red key
OP
OP
Luke M
Luke M
Formerly mog1571
widnes, liverpool
ok. my keys has a code engraved in with a C then 3 numbers. will this be the code number for my car? or is this just a part number and not specific to my car?
AppleSei
RIP L181 VBB
West Yorks
wat numbers are on it? The symbols and numbers usually indicate that it is a type2 system IIRC, although you can deffo rule out buying that ebay key now
OP
OP
Luke M
Luke M
Formerly mog1571
widnes, liverpool
its got the little radio triangle with the number 2 on and also got C265 engraved where the plastic ends. is this a part number for the basic key or is it genuine to my key?
Hellcat
zombie nation
on the A684
Are these the typical fiat keys or the alfa style flip key?
Timpsons quoted me £20 to cut and clone my Marea key, cutting from my red key and cloning a blue
OP
OP
Luke M
Luke M
Formerly mog1571
widnes, liverpool
its the ordinary blue fiat key. im just tryna work out if the code on the key is for my individual key thats been linked or wether its just a part code for a blank unlinked key
AppleSei
RIP L181 VBB
West Yorks
C265 is on all my keys as well, doesnt look like a code, maybe it is a type of reference number, and makes it easier for replacement of a new one for the dealers etc i.e dont give you a punto key for example its a code2 for definate though
AppleSei
RIP L181 VBB
West Yorks
These are code2 keys rob so there is no red key at all
OP
OP
Luke M
Luke M
Formerly mog1571
widnes, liverpool
ok cheers mate. i knew i didnt need a red key. i guess that code must be a part number. looks like its a trip to fiat!
