SeiAbarth99
- Joined
- Jun 27, 2013
- Messages
- 6
- Points
- 1
I'm new to this site so soz if this is posted on the wrong forum. Basically, recently some negative vibe merchant ran into the front wing of my 1999 Seicento Sporting 1.1 Abarth. There wasn't much damage to the wing itself, but on inspection it looked like a bent suspension strut and a slightly bent lower wishbone arm.
So a quick look for parts on a well known web-based auction site and I ordered a new wishbone arm for £23 and a used suspension strut (complete with springs, etc) for about £40. All good and well so far. However, after removing the strut from my Sei (using the helpful guide on this site) it was clear that the replacement doesn't quite match up with the one from my car.
Although the strut itself looks almost exactly the same and the lower section measures up, the spring on my strut was around 60mm shorter. The spring is around 175mm compressed on mine and around 235mm on the replacement.
So my question is basically:
Is it possible to swap the spring from my old strut onto the replacement and use the resulting suspension leg, or are the two struts different somehow?
Cheers,
(NB - I'd post some pics of the struts to show what I mean but I haven't made enough posts yet)
Cheers,
