The outer boot wants replaced 19mm seems a tad small for the drive shaft hole at the small end on one on ebay. Seen another saying 21mm so What diameter is the drive shaft if anyone knows?
I noticed that. Big Mick and Little Mick Any of you two happen to know the wheel nut thread size, does 12mm x 1.25mm / 28mm sound about write. Got a few tight spots in the O/S front hub to looking to buy a tap or is it die to give the hub threads a clean up.
