Technical Seicento coolant temp warning light
Catikk
I've got a 1999 Seicento Sporting which I've had since December, no problems with it but about 6 months ago the coolant temperature warning light (right hand side of dash, red light looks like a thermometer) started flickering on and off. It then stopped for a while but has been flickering again for the past few months. It does it from cold so I find it very hard to believe that the car is overheating, so I think it must be a sensor problem, as the light never stays on, it just flickers. It also comes on more then I'm accelerating and goes off when I lift off the accelerator. It is rather irritating! The car runs completly fine and the fan comes on regularly when its warm. Anyone seen this before or have any advice as to what I can do to sort this without a visit to a Fiat dealer!!
custard
Status: DEFCON Grumpy
Edinburgh
i would be checking the wiring 1st,could be as siple as a loose/broken connection at the coolant sensor
rallycinq
Autotest Special
Lake District....Moist
As the engine rocks during acceleration, follow the wire to where it mounts in the loom, wiggling as you go, with the ignition on, and somebody watching the light.
Bedfordshire
I have just had the same problem for the last two weeks, but before playing with the bloody car... can you let us know where abouts the coolant sensor is? Although i have a 2001 sei sporting does it really make any difference?
