MDR
Grateful if anyone out there can provide me with some clues as to what may be wrong with the gearbox on a SEI that I recently purchased for my daughter. She has a lovely little 1999T Sei Citymatic (900cc) with about 16k on the clock - it has the semi-automatic (clutchless gearbox). She has recently been have a few problems the basically fall into the following:
a. Difficulty selecting reverse gear.
b. When 1st or reverse are selected and the accelerator is pressed the car 'thuds' quite violently and can, if you don't accelerate through, stall.
c. The change from 1st to 2nd is also juddering. Gear change in the upper gears seems ok but......she was driving today and simply could not select 5th or any other gear for that matter - car was stuck in neutral and could have been ruddy dangerous if she could not have pulled over immediately. On this occasion the ACS (Auto Clutch System) light also came on and she was unable to start the car for several minutes.
Thats the best I can describe the symptoms. But am at a loss as to what it might be - the ACS light does not come on at system check but the 'thud' in 1st and reverse is still there. Grateful, before I approach Fiat or an independant specialist, that someone out there might be able to give me some 'am I getting ripped off' advice and knowledge.
Many thanks in advance - came upon the website tonight trying to find some info - very impressed (particularly with Pete)...cheers,
Mick
Mick
