- Joined
- Feb 16, 2005
- Messages
- 5,983
- Points
- 988
depending on the fault code triggered, starting the car 3 seperate times, without the fault triggering the code, will cause the light to vanish
this doesn't work with all stored codes, but does with lots.
Running without IAT and MAP will be giving the car so VERY funky fuelling and ignition readings. Best not to do it lol
Resetting the ECU prob won't remove the fault, and worst comes to worst, you will need to reset it.
Trying to diagnose it is tricky, could be anything! You done stuff like compression test on it?
Kristian
Kristian
