panda_owner
I have another question. does anybody know where I could find some schematics (mechanical and/or electrical) about fiat panda 750 FIRE/non FIRE?
thanks in advance!
thanks in advance!
Originally posted by panda_owner
So I installed a regular PC fan (the one on the processor) and added a LE diode so I can see if there is no spark in case car won't start.
Originally posted by FatNote
I think I can help with this one...
I had EXACTLY this problem on my Lancia Y10 last year, which has the same Magnetti Marelli distributor. It would cut out... of course, only in traffic in downtown Geneva [!] (due to high temperature) and then start up perfectly after about 15 minutes.
In my case it was the amplifier module on the distributor (the thing with the heat sink on it, right John H?). I replaced only this part and I've never had that problem again.
As a quick and dirty test of my theory: when it cuts out again, try dissipating a little heat from the module (say, just by placing your hand on the heat sink) and then check that it will start back up much sooner.
