Anyone recommend a good place to buy some yellow pipes from? i've found one place that can give me a lead time of 10 days (much better than 6-10 weeks!) but pretty expensive imo... may be wrong though...
The below is what i need on the order:
38mm ID 90 deg hoses, 102mm leg x3 (boost pipe)
38mm ID 90 deg hose, 152mm leg x1 (boost pipe)
44mm ID 135 deg hoses x2 102mm leg (induction pipe)
25mm ID straight 76mm long (for dumpvalve fitting)
25mm ID straight 1metre (oil breather pipe)
19mm ID straight 1m length (coolant pipe from the 4 block to the expansion tank)
10mm ID straight, 1m length (top of expansion tank to the throttle body)
8mm ID straight, 3m length (vacuum pipes and general bay tidyup)
at the current website the above is costing me 189.99 + 8.50 vat, but the guy has offered me a discount code on this but not told me how much the discount would be for... does this sound like a good price to you guys
also did ask him about a fluro pipe for my oil return on turbo but sold in 1m sections, at over £50 a metre only need like 60mm or something iirc so may leave that for now
just hope this sorts my boost leak
edit: the alternative would be to buy the smaller pipes as part of one of those engine bay dressup packs for like £15.00 but this may not be of the same quality?
