Hi mate
The other guy's advice is spot on
My own preference is to use a marine grease (I'm guessing a normal "oily" grease will do just fine) and brush that stuff everywhere you can. Very good for your steel brake lines too. Probably best to keep it away from rubber bushes and of course the brakes
I've done the entire underside of my car with gallons of the stuff and sprayed oil/waxoyl/WD40 etc inside the chassis rails/sills you name it. WD40 inside the doors via the drain holes and in the strut tops/hinges/bonnet release etc.
I found that if you open the tail gate and have a poke around you can spray WD40 through where the aperture is for a boot light (I think thats what I used lol) and its runs down over the rear wheel arches inside (perfect, keeps water out, no rust) and along the sill, all the way to the front.
I know it sounds messy but once you've done this and driven a few miles (let it drain off for a good while first, bikes etc) it just ends up being a uniform dark looking coating that seems to look after the car very well underneath.
In my opinion its well worth spending half a day doing this against all the salt they have to put on our roads
Good luck with whatever you decide to try mate
