Apparently tesco fuel has the ol' silica issues again got a Heads up off of my bro at 6pm... its un confirmed at the moment but thought i should let you guys know... remember to get your receipts
Whats that?
I literally just filled up £20 at tesco less than an hour ago :bang:
a select few tesco stores last year had bad fuel doses with high levels of silica (mineral) in them. it bunged up Lambda sensors left right and centre the only remedy was flush the fuel and fit new Lamdas
it happened when the exhaust got upto temperature the silica deposists melted around the lamdas and blocked them up with a glass/sandy substance... dont panic too much just yet as i said its UNCONFIRMED atm
richydrapers brother said:forums have started claiming tesco is having fuel issues again, bad running etc.
not confirmed, but thought you'd just like a heads up.
similar symptoms to a few years ago; bad running and lambda values all messed up.
i fancy a new lamba sensor, think it could effect my cat as well?
hope it isn't true i need to fill up and the cheapest place around is tescos
