could someone explain to me what "RMS" means on subs/amps as its causing me a little bit of confusion
chrisunoman said:... which is what Gaz does.
If you have for example a pair of 100w rms speakers, the best amp to get would be a 2 channel 2x100w rms or maximum 2x125w rms.
You should either match the rms, or get an amp with the rms output ever so slightly higher,
