dabravokid
I have a 99 Bravo 100SX and for the most part its a great car. I have a niggling problem with the revs occasionally, every couple of days. Basically it will start to rev higher then 1000 (normal is 800), when the fan cuts in it sometimes goes upto 1500 (doesn't move from 800 normally). It also makes changing gear harder and kangeroos slightly. It has been to fiat (who seem to rely solely on the diagnostic tool) and they say 'we can't find anything wrong' damn technology! You would have thought the builder of this tool could have put a little prompt saying that they should try something else. Anyway the first time in they changed the throttle body (warranty). This didn't really have an effect. Then I did an ECU reset, no effect. I'm starting to think it could be something to do with the Lambada or some other sensor. How hard is it to change the lambada sensor? I'm fairly handy with a spanner and have axel stands. In the meantime fiat are going to replace the temperature sensor because that sometime seems register higher then normal. For info this problem occurs even when the engine is hot. Thanks in advance for help.
