Mark075
This is a head scratcher. I noticed my reverse light wasn't working (when I was reversing suprisingly) so I checked the bulb. It looked fine so I put in place of the fog light to check it. It worked fine in there. I then put the bulbs back in their rightful places.
I then checked the fusebox and found that it was 5a fuse and was blown. Looking at the manual it should be 7.5a so thought that was probably the problem. I didn't have a spare 7.5a so I stuck another 5a fuse in its place. This blew as soon as I put the car in reverse.
The next best fuse I had was 25a. Perhaps misguidedly, I placed this in the fusebox and then put the car in reverse. This blew the 20a fuse in the engine bay which prevented all functions on the car from working (quite worrying at first until i found the fuse!!)
There is clearly an issue with the wiring causing the fuse to blow everytime. Has anyone experienced anything similar or have any ideas? It's not a massive issue now but may be when MOT time comes round.
