General resetting the ECU?
Glasgow
hi there,
Is there anyway i can reset my ecu ??
Does pulling the two battery cables out work???
Or that's just bull **** :p?
thanks in advance
bye for now
Liverpool
That'll work. Opinions differ on how long you need to disconnect for. Overnight should well do it, but I can't see why more than an hour is needed.
Why you want to reset?
OP
OP
Y
Glasgow
the engine management came on, so lambda sensor is change ^^.
I suspect is the lambda sensor due to the fact that the light only comes on when the engine is hot and stays off with a cold engine.
Just so the ECU will stop thinkikng some sort of sensor is at fault.
And after i put the lambda sensor, yet the engine light came on again ~~~~~
I really hope by resetting the ECU will fix this :). well i guess i will leave it over light
OP
OP
Y
Glasgow
that shouldn't be problem, when i was replacing it, i took the whole wire out connecting from the ecu onwards. .. i am just afraid that it could be some other sensor that causes the engine light to come on ....
i think when that comes i might have to get my ecu read again .... tomorrow i'll clean the throttle body hope that will help ...
thanks for the help :)
Liam
hi friends :waves:
Scotland
Search for haynes ecu reset and you'll find the proper procedure.
Liam
OP
OP
Y
Glasgow
hi there i have with those keywords , but i can't seem to find anything.
can you post a link please??
thanks again
SkinzCinqSporting
MG ZR Owner :)
Well put it this way, i took the ECU out and it reset itself, and better than having to reprogramme your radio presets and clock :)
OP
OP
Y
Glasgow
i see i see , well i guess pulling the battery out also works..
ok i resetted the ecu, and now the car seems to misfiring constantly ~~~~~~
any hlep on that ?? Is this because the ECU has been resetting and has to learning about the fuelling again ??
frenchwood
Nottingham
The ECU in Centos is a "Learning" ECU.
After you reset it (mine resets after a brief disconnection) it needs to "Re-Learn" the engine.
IMHO it usually takes about 300 miles to relearn, and during this time will drink petrol and run like a bag of ferrets arguing over a dog bone.
I tend to find after a reset that i can expect poor performance for around 3-4 days, after this it should be running "Normal"...
Hope this helps!
(y)
