- Joined
- Oct 10, 2021
- Messages
- 614
- Points
- 232
This one would be a no-brainer on a Subaru since it's permanent 4x4 - you need to replace all 4 tyres at once to avoid centre diff wear, but on an Abarth, should you replace tyres in pairs or replace all four at once if you're changing to a different brand?
I've got some new lightweight 7jx17 wheels coming very soon (which means the tyre size will remain unchanged) and in this situation normally I'd just swap the tyres over to the new rims if the sizing remained unchanged.
But one of the front P Zero Neros is a bit worn (back ones are perfect) and the other one has been impacted in a crash so I wouldn't trust it any more. Since Goodyear Eagles look like a no-brainer as a replacement (cheaper, better grip, better wet braking, etc) it'll be getting those to replace the two fronts, but not sure what to do about the rears.
They're 'as new' (presumably the tyres weren't rotated) but since the handling characteristics are very different to the Eagles, I'm wondering if I should replace them too, or if, because the back end's so light, the rears do little but stop the backside from rubbing along the ground?
If they do have a significant effect I'd be best changing them since the more grippy fronts and less grippy rears could result in unpredictable oversteer, but if they pretty much carry no load it's going to make little difference what I do at the backside, so might as well leave the P Zeros on there.
