Technical Replacing the speedo Cable...
Kent
Hi Guys,
Is replacing a speedo cable easy or shall i book it into a garage to get done??
If it easy could someone do me a step by step guide by any chance...
Not too sure i think the cable comes in two parts. You will have to take the top piece of dash off and remove the clocks which are held in with 4 self tappers. Then release the cable at the back by pushing the outer ring backwards which releases it. Then should just run into the cabin. Should be a piece of **** compared to clutch cable.
Its not getting the cable off the back of the dials its putting it back on that is the ball ache because you have to push the cable onto the spike nd hold it there while you nove the sleave back over it. All this with about 2" of space for your hand to go through
